Home > Off Topic > Solved! Garage lights wiring |
back in 16th 17th days wiring using 3 phase 3 wire for single phase
RED OR BROWN - LIVE YELLOW OR BLACK - EARTH (SLEEVED GREEN/YELLOW) BLUE OR GREY - NEUTRAL (SLEEVED BLUE) |
5th Nov 2018 1:41pm |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 |
those are some lights for a garage! Looking at the spec they have a carrier tray that takes the tubes. I would check that that is correctly installed and you are getting voltage to the fittings in the first instance. Are the ballasts correctly installed and the lamps/tubes working?
5th Nov 2018 2:02pm |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 |
Hi
Sorry for my ignorance may i ask what does this mean??? "back in 16th 17th days wiring using 3 phase 3 wire for single phase" I havent opened them up, screw on end caps are proving tough to open but I guess if I have wired them up ok. Brown to Red Blue to Blue Green/Yellow to yellow Then I guess next step is to check inside! |
5th Nov 2018 2:57pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Well they are not cheap lights, depending on size over a grand.
Now a quick search shows 3 wires + earth on spec sheet here with 230 volts standard PLUS other voltages. First think is to check the specification plate and see what voltage it is. 16/17th are editions for electrical regulations which sparkies adhere to. Brendan |
5th Nov 2018 3:20pm |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
Well they are Petrel Series 7 hazardous area Ex d fluorescent fittings so require a 230v supply so should work as you have had them connected. Maybe tubes need replacing or possible starter inside the fittings.
5th Nov 2018 3:21pm |
Click image to enlarge SWA wire you are showing manly used for 3 phase 3 wire 415 volt CCT , But also used single phase 240 v and wire used older wire---------------------------------------- newer wire RED LIVE --------------------------------------- OR BROWN - LIVE YELLOW EARTH (SLEEVED GREEN/YELLOW)----- OR BLACK - EARTH (SLEEVED GREEN/YELLOW) BLUE NEUTRAL ------------------------------------ OR GREY - NEUTRAL (SLEEVED BLUE) this is used as elect industry stranded Last edited by dorsetsmith on 5th Nov 2018 3:48pm. Edited 2 times in total |
5th Nov 2018 3:24pm |
Hmm
So end cap removed! Spot the problem! Winner gets a smartie! They are great lights ive been looking for ages and these come up on ebay! massively heavy but look great. Thanks for your help on this one. Click image to enlarge |
5th Nov 2018 3:39pm |
Well yes it helps if they are plugged in 😄
5th Nov 2018 3:59pm |
Danah!
5th Nov 2018 4:01pm |
