![]() | Home > Off Topic > Solved! Garage lights wiring |
back in 16th 17th days wiring using 3 phase 3 wire for single phase
RED OR BROWN - LIVE YELLOW OR BLACK - EARTH (SLEEVED GREEN/YELLOW) BLUE OR GREY - NEUTRAL (SLEEVED BLUE) |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
those are some lights for a garage! Looking at the spec they have a carrier tray that takes the tubes. I would check that that is correctly installed and you are getting voltage to the fittings in the first instance. Are the ballasts correctly installed and the lamps/tubes working?
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 ![]() ![]() ![]() |
Hi
Sorry for my ignorance may i ask what does this mean??? "back in 16th 17th days wiring using 3 phase 3 wire for single phase" I havent opened them up, screw on end caps are proving tough to open but I guess if I have wired them up ok. Brown to Red Blue to Blue Green/Yellow to yellow Then I guess next step is to check inside! |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Well they are not cheap lights, depending on size over a grand.
Now a quick search shows 3 wires + earth on spec sheet here with 230 volts standard PLUS other voltages. First think is to check the specification plate and see what voltage it is. 16/17th are editions for electrical regulations which sparkies adhere to. Brendan |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
Well they are Petrel Series 7 hazardous area Ex d fluorescent fittings so require a 230v supply so should work as you have had them connected. Maybe tubes need replacing or possible starter inside the fittings.
![]() Click image to enlarge SWA wire you are showing manly used for 3 phase 3 wire 415 volt CCT , But also used single phase 240 v and wire used older wire---------------------------------------- newer wire RED LIVE --------------------------------------- OR BROWN - LIVE YELLOW EARTH (SLEEVED GREEN/YELLOW)----- OR BLACK - EARTH (SLEEVED GREEN/YELLOW) BLUE NEUTRAL ------------------------------------ OR GREY - NEUTRAL (SLEEVED BLUE) this is used as elect industry stranded Last edited by dorsetsmith on 5th Nov 2018 3:48pm. Edited 2 times in total |
Hmm
So end cap removed! Spot the problem! Winner gets a smartie! They are great lights ive been looking for ages and these come up on ebay! massively heavy but look great. Thanks for your help on this one. ![]() Click image to enlarge |
Well yes it helps if they are plugged in 😄
Danah!
