Home > Td5 > Drivers window not working |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5416 |
The window not working will be broken wire between A post and door. It will be in the rubber conduit. They may look ok but one will be snapped inside insulation. It will be the two thick wires for window.
Clocks will just be bulb. |
28th Oct 2018 7:05pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
assuming your defender is standard wiring, then your first place is to check into the passenger compartment fuse box to see if the fuse has blown.
then move on to the wiring in the A pillar and then finally removing the door card to check at the connectors if there's power. if there's power, then it's time to either rebuild the motor (yes, it's possible if you have the time and skills) usually it stops working because of water in the motor and it starts rusting away. Failing which just replace the entire assembly (lifter and motor) you can't buy the motor alone From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
6th Nov 2018 8:10am |
