Home > Td5 > Drivers window not working
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
Hello
My 2003 90 TD5 all of the sudden has the drivers side electric window not working... when I press the switch nothing happens. Do you know whether it might be a fuse and if so which one?
Also it looks like half of the speedometer light is off as per picture... maybe related?
Lastly it also looks like the DB antenna is not working...
Any suggestion is appreciated.
Best
Alex
Post #737268 28th Oct 2018 7:03pm
landy andy
The window not working will be broken wire between A post and door. It will be in the rubber conduit. They may look ok but one will be snapped inside insulation. It will be the two thick wires for window.
Clocks will just be bulb.
Post #737269 28th Oct 2018 7:05pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
assuming your defender is standard wiring, then your first place is to check into the passenger compartment fuse box to see if the fuse has blown.
then move on to the wiring in the A pillar and then finally removing the door card to check at the connectors if there's power.
if there's power, then it's time to either rebuild the motor (yes, it's possible if you have the time and skills) usually it stops working because of water in the motor and it starts rusting away.
Failing which just replace the entire assembly (lifter and motor) you can't buy the motor alone The defender has migrated, leaving the owner behind.
Post #738945 6th Nov 2018 8:10am
