Home > Puma (Tdci) > Swivel Seals, ABS Issue ? |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 427 |
Sounds like a sensor to me. Might be able to take the guesswork out of it if you get diagnostics on it. Should be able to tell you wheel speed from each wheel.
There's a Land Rover Toolbox video on youtube recently that'll tell you exactly what to do to diagnose it if that's the route you want to take. |
23rd Oct 2018 10:01pm |
https://youtu.be/myvy8zN4F4U?t=232
This should be the bit you're after. |
23rd Oct 2018 10:08pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
Thanks for that link,, not quite sorts it,, will have to find some time, to have a look and see whats causing the fault ! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
26th Oct 2018 11:42am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2227 |
Are the ABS sensors fully located “home” ? Check they’re pushed fully down into their sockets
26th Oct 2018 12:03pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2641 |
You sorted this yet Tim? 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
27th Oct 2018 5:29pm |
Well, have had it all to bits again, both sides, ABS sensors out and cleaned/checked, same 3 shims on them as before & torqued down
All refitted, and ABS kicks in still , maybe even more so, than before !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
6th Nov 2018 6:13pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
Did you reset the swivel pre load when you did the seals?
From memory on my 200 bitsa the abs sensor is through the top swivel bearing, if there's too much play in the swivel it may make the seals weep and could upset the abs setting Keith |
6th Nov 2018 7:14pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
Any codes present? Can you graph the sensors at low speed and see any drop outs?
7th Nov 2018 12:35am |
Stu_XS Member Since: 22 Jul 2018 Location: Hampshire Posts: 86 |
I had a similar issue recently whereby the front right would lockup on ABS/TC.
I took out all of the sensors, cleaned them, applied a smear of anti seize grease a popped them all back in. Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
7th Nov 2018 12:40am |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 755 |
Did you change the tiny needle roller bearing inside the stub axle (assuming its the same as a td5 one).
Did swivel seals on my td5 some years ago then had the same problem when we had set everything up again- changed the tint bearing and that sorted it. Think ill be doing the same again on the opposite side in the new year.... Chris |
8th Nov 2018 9:59pm |
Update & sorted
Issue with r/h front ABS sensor, new one cure it,, either coincidence (3.5 years and 11,000 miles !!) or the wire was damaged somehow when the hub was striped down for seal replacement ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
9th Nov 2018 9:43am |
