Home > Puma (Tdci) > Swivel Seals, ABS Issue ?
TJ101
Evening all
2015MY 110, 11,000 miles, and just replaced both weeping swivel seals
Full kit, all parts gen and everything,
Now have the brake pedal ABS pump kicking in at slow speed before stopping, about 3/5 mph, to standstill,
Gut feeling its right hand side ??
Before i strop it all down again, any ideas ? Guessing maybe a sensor not seated correctly ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #736418 23rd Oct 2018 9:29pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Sounds like a sensor to me. Might be able to take the guesswork out of it if you get diagnostics on it. Should be able to tell you wheel speed from each wheel.
There's a Land Rover Toolbox video on youtube recently that'll tell you exactly what to do to diagnose it if that's the route you want to take. Thumbs Up
Post #736424 23rd Oct 2018 10:01pm
BenB8man
https://youtu.be/myvy8zN4F4U?t=232
This should be the bit you're after. Thumbs Up
Post #736426 23rd Oct 2018 10:08pm
TJ101
Thanks for that link,, not quite sorts it,, will have to find some time, to have a look and see whats causing the fault ! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #736849 26th Oct 2018 11:42am
hank
Are the ABS sensors fully located “home” ? Check they’re pushed fully down into their sockets
Post #736854 26th Oct 2018 12:03pm
walfy
You sorted this yet Tim? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #737073 27th Oct 2018 5:29pm
TJ101
Well, have had it all to bits again, both sides, ABS sensors out and cleaned/checked, same 3 shims on them as before & torqued down
All refitted, and ABS kicks in still , maybe even more so, than before !! Rolling Eyes California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #739031 6th Nov 2018 6:13pm
ickle
Did you reset the swivel pre load when you did the seals?
From memory on my 200 bitsa the abs sensor is through the top swivel bearing, if there's too much play in the swivel it may make the seals weep and could upset the abs setting
Keith
Post #739045 6th Nov 2018 7:14pm
NickMc
Any codes present? Can you graph the sensors at low speed and see any drop outs?
Post #739137 7th Nov 2018 12:35am
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
I had a similar issue recently whereby the front right would lockup on ABS/TC.
I took out all of the sensors, cleaned them, applied a smear of anti seize grease a popped them all back in. Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #739138 7th Nov 2018 12:40am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Did you change the tiny needle roller bearing inside the stub axle (assuming its the same as a td5 one).
Did swivel seals on my td5 some years ago then had the same problem when we had set everything up again- changed the tint bearing and that sorted it.
Think ill be doing the same again on the opposite side in the new year....
Chris
Post #739421 8th Nov 2018 9:59pm
TJ101
Update & sorted
Issue with r/h front ABS sensor, new one cure it,, either coincidence (3.5 years and 11,000 miles !!) or the wire was damaged somehow when the hub was striped down for seal replacement ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #739464 9th Nov 2018 9:43am
