![]() | Home > Maintenance & Modifications > Hand brake right shoe retaining pin - what’s the secret!! |
Emptywallet Member Since: 03 Mar 2018 Location: Alresford Posts: 31 ![]() ![]() ![]() |
Answer is to remove cubby box, remove the access panel and get your wife to hold the pin in position from above with a wrecking bar. What a palava!
All sorted now. |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 268 ![]() ![]() ![]() |
Hi Emptywallet
Sorry just seen your post and know this not a lot of help now! I had the same issue and managed to fix it by unbolting the handbrake back plate from the transfer box and remove the hand brake cable. Assembling the brake shoes and hand brake cable to the back plate off the vehicle and then bolt the rebuilt assembly back to the transfer box. |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
I did the hard side 1st then wedged the harder one in place. Took a few attempts and lots of swearing 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17929 ![]() ![]() ![]() |
Unbolting the whole handbrake assembly from the transfer box is usually easiest.
Cheers all for your replies. I hope I never have to change that bloody cable again!
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Wee buns
![]() Seen people use needle nose pliers or blu-tack |
