Home > Maintenance & Modifications > Hand brake right shoe retaining pin - what’s the secret!!
Emptywallet
United Kingdom 2005 Defender 110 Td5 CSW Tonga Green
Need some advice please.
Had to replace a frayed handbrake cable on my 2005 110. Cable now in place, but how on earth do you hold the retaining pin for the right hand shoe when you need to push on the spring and retaining cap!?!?!
This should be such a simple operation, but seems a really silly design if you cannot get access to the back of the drum to hold it in place.
Post #731697 28th Sep 2018 5:48pm
Emptywallet
Answer is to remove cubby box, remove the access panel and get your wife to hold the pin in position from above with a wrecking bar. What a palava!
All sorted now.
Post #731823 29th Sep 2018 9:38am
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi Emptywallet
Sorry just seen your post and know this not a lot of help now!
I had the same issue and managed to fix it by unbolting the handbrake back plate from the transfer box and remove the hand brake cable.
Assembling the brake shoes and hand brake cable to the back plate off the vehicle and then bolt the rebuilt assembly back to the transfer box.
Post #731828 29th Sep 2018 10:06am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I did the hard side 1st then wedged the harder one in place. Took a few attempts and lots of swearing 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #731832 29th Sep 2018 11:01am
Unbolting the whole handbrake assembly from the transfer box is usually easiest.
Post #731860 29th Sep 2018 4:05pm
Emptywallet
Cheers all for your replies. I hope I never have to change that bloody cable again!
Post #732066 30th Sep 2018 9:49pm
NickMc
Wee buns Whistle
Seen people use needle nose pliers or blu-tack
Post #732088 30th Sep 2018 11:33pm
