Home > Maintenance & Modifications > OME 2767 & 2752 spring lift height
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
I’m looking for feedback on the Old Man Emu spring combo 2767/2752
I really don’t want to lift the truck by much, but with a off road bumper and winch up front I have about 175 lbs of static weight. The rear has much less- maybe 100lbs total static weight.
Hoping these springs will keep me under 2” and forgo the need for a DC drove shaft. Any experiences?
Post #731360 26th Sep 2018 5:09pm
rallysteve
See here for 2751s on my 110 if it is any help:
http://www.defender2.net/forum/topic52032.html 02' 110 TD5 Double Cab Rebuild Thread
Post #731362 26th Sep 2018 5:22pm
Bps
I’m pretty sure they are the same set up as mine but will have to check the paper work tomorrow to confirm.
If they are the rear is the same height as a standard heavy duty mod spec spring, just a softer ride ( my 110,s a tithonus and not to much in the back)
On the front I put a 1” Gwyn Lewis spacer in as I’ve got a d44 high mount and steering and goodwinch on the front and don’t like the nose down look on a defender.
I went with +5 ome shocks and it’s a nice ride. Rolls a little when entering a corner but then settles but I didn’t build it for speed, fantastic off road with the rest of Gwynns kit
Post #731398 26th Sep 2018 8:09pm
big110
Thanks for looking I appreciate it!
Post #731399 26th Sep 2018 8:12pm
Bps
Sorry for taking so long to get back to you. I took me a while finding the paper work
Mine are 2751 front 2755 rear
Post #731878 29th Sep 2018 6:11pm
MK
Mine are also 755 and 751 giving 25-30 mm lift in the back and 20mm in the front.
OME2767 will be very stiff at 285lbs/in and 2752 is quite soft. I recommend you check on http://www.oldmanemu.com.au/old-man-emu-suspension-selector/ Puma 110" SW
Post #731897 29th Sep 2018 7:59pm
