![]() | Home > Maintenance & Modifications > OME 2767 & 2752 spring lift height |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
See here for 2751s on my 110 if it is any help:
http://www.defender2.net/forum/topic52032.html 02' 110 TD5 Double Cab Rebuild Thread |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 847 ![]() ![]() |
I’m pretty sure they are the same set up as mine but will have to check the paper work tomorrow to confirm.
If they are the rear is the same height as a standard heavy duty mod spec spring, just a softer ride ( my 110,s a tithonus and not to much in the back) On the front I put a 1” Gwyn Lewis spacer in as I’ve got a d44 high mount and steering and goodwinch on the front and don’t like the nose down look on a defender. I went with +5 ome shocks and it’s a nice ride. Rolls a little when entering a corner but then settles but I didn’t build it for speed, fantastic off road with the rest of Gwynns kit |
big110 Member Since: 02 Nov 2016 Location: Pinner Posts: 388 ![]() ![]() ![]() |
Thanks for looking I appreciate it!
Sorry for taking so long to get back to you. I took me a while finding the paper work
Mine are 2751 front 2755 rear |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492 ![]() ![]() ![]() |
Mine are also 755 and 751 giving 25-30 mm lift in the back and 20mm in the front.
OME2767 will be very stiff at 285lbs/in and 2752 is quite soft. I recommend you check on http://www.oldmanemu.com.au/old-man-emu-suspension-selector/ Puma 110" SW ............................................................. Earth first. Other planets later |
