![]() | Home > Maintenance & Modifications > Leaking lower swivel pin |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
It is as straightforward as that. Remember to put a bowl underneath to catch the oil/grease that will flow out and get yourself a pack of 'one shot' grease to refresh the swivel lube afterwards.
Also support the hub assembly too so the top swivel is not taking all the weight Preload is adjusted with shims on the top swivel so you shouldn't need to readjust that if you're only playing with the bottom swivel. Go for it - 20 minute job from getting the jack out to putting the jack away again ![]() |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 836 ![]() ![]() |
Thanks for the reply & advice.
Will give it a go when I get a chance. BORG - Bucks & Oxon 4x4 Response Group ![]() |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Some years have an o-ring on the lower pin.
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
let me know when Dylan and I can give you a hand. 1995 Defender 110 CSW
1971 SIIA Lightweight |
