Home > Maintenance & Modifications > Leaking lower swivel pin
mini Anaconda
I have a leak from my lower swivel pin which I need to fix. I have bought the relevant gasket but I'm not sure if its ok to just remove the pin. clean, fit new gasket and re-fit the lower pin. Is it as straight forward as that or is some sort of disaster likely to happen? I should mention its a Discovery 1 axle if that makes any difference?
Thanks in advance. BORG - Bucks & Oxon 4x4 Response Group
Post #728140 9th Sep 2018 8:09pm
hank
It is as straightforward as that. Remember to put a bowl underneath to catch the oil/grease that will flow out and get yourself a pack of 'one shot' grease to refresh the swivel lube afterwards.
Also support the hub assembly too so the top swivel is not taking all the weight
Preload is adjusted with shims on the top swivel so you shouldn't need to readjust that if you're only playing with the bottom swivel.
Go for it - 20 minute job from getting the jack out to putting the jack away again Thumbs Up
Post #728213 10th Sep 2018 5:53am
mini Anaconda
Thanks for the reply & advice.
Will give it a go when I get a chance. BORG - Bucks & Oxon 4x4 Response Group
Post #728544 11th Sep 2018 9:01pm
NickMc
Some years have an o-ring on the lower pin.
Post #728702 12th Sep 2018 11:05pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
let me know when Dylan and I can give you a hand. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #728737 13th Sep 2018 10:56am
