![]() | Home > Puma (Tdci) > 2..4 Fuel economy |
Bergos Member Since: 08 Aug 2015 Location: Somewhere in Portugal Posts: 95 ![]() ![]() ![]() |
Hi.
My car is a 110 HardTop. Full roll cage, winch, full underbody guars (most of them made of aluminium). LR HD suspension. 265/75R16, wolf rims. Oil - 5W40. What economy should I expect? When I drive up to 100km/h I can arrive to 10l/100km. Going 120-130km/h in a highway is decreasing it to ~12.5l/100km. The thing is that 3 years ago the consultation was 10 litres on the highway. In the meantime I put the roll cage and a snorkel. Not too many more mods that could make a difference. Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
My 2.4 with same tyre size averages around 10.5-11km/L with the following driving profile:
- 60% countryside with rolling hills with speeds approx 50-75km/h - 30% highway at speed 100-105km/h - 10% town with speeds <50km/h Load typically 2-3 persons + 100kg "stuff". All oils as per spec. I have also recently started running 2 stroke oil in the fuel (ratio 200:1). Can't say I've noticed the fuel consumption changing (need a few more tanks to reach a conclusion) but engine seems to run smoother and cleaner (less smoke). Others have reported improved fuel consumption though. |
Now the big question is how does this oil protect the engine in hot climate - 40-45°C? Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4338 ![]() ![]() ![]() |
If you are using a quality one, like Motul Specific 913D, probably fine. I would certainly stay away from the cheaper ones if you are running extreme conditions. Did LR ever specify a different grade hotter climates? 2007 110 TDCi Station Wagon XS
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684 ![]() ![]() ![]() |
see my sig --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
best I've managed on a standard 110xs with remap is 7.037ltr / 100km (ie 40mpg)
in terms of economy speed is the work of the devil, on need to be cruising at about 80-85kmh. ![]() |
Hal Member Since: 04 Jun 2014 Location: Bedford Posts: 91 ![]() ![]() |
Over the last 12 months, 6000 miles, my 2011 110 station wagon has averaged out at 29.4 imperial mpg = 9.6 l/100km. That's with standard spec oils, winch, guards, 100kg of stuff in the back, over all sorts of driving inc. light towing., green lane, motorway long distance, whatever.
But every individual fill-up is different, depends what I've been doing. |
pme Member Since: 06 Jan 2016 Location: cambridge and mainly ariege Posts: 49 ![]() ![]() ![]() |
Same as Hal, long term average over 15000km 10l/100km and the hill here are quite big
