Home > Puma (Tdci) > 2..4 Fuel economy
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
2..4 Fuel economy
Hi.
My car is a 110 HardTop. Full roll cage, winch, full underbody guars (most of them made of aluminium). LR HD suspension. 265/75R16, wolf rims.
Oil - 5W40.
What economy should I expect?
When I drive up to 100km/h I can arrive to 10l/100km. Going 120-130km/h in a highway is decreasing it to ~12.5l/100km.
The thing is that 3 years ago the consultation was 10 litres on the highway. In the meantime I put the roll cage and a snorkel. Not too many more mods that could make a difference. Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #725362 25th Aug 2018 6:33pm
Bluest
A Puma 2.4 should run 5w30, which could account for a small loss in economy if you switched to 5w40 at some point along the way. Also, the Ford spec for a Puma is specifically for a fuel economy engine oil (I think it is WSS-M2C913-B) that resist the increase in viscosity that usually happens as an oil ages. If your current oil isn’t specifically a fuel economy formula then that too may account for a small loss. 2007 110 TDCi Station Wagon XS
Post #725366 25th Aug 2018 6:52pm
redline
Switzerland
My 2.4 with same tyre size averages around 10.5-11km/L with the following driving profile:
- 60% countryside with rolling hills with speeds approx 50-75km/h
- 30% highway at speed 100-105km/h
- 10% town with speeds <50km/h
Load typically 2-3 persons + 100kg "stuff". All oils as per spec.
I have also recently started running 2 stroke oil in the fuel (ratio 200:1). Can't say I've noticed the fuel consumption changing (need a few more tanks to reach a conclusion) but engine seems to run smoother and cleaner (less smoke). Others have reported improved fuel consumption though.
Post #725371 25th Aug 2018 7:24pm
Bergos
Now the big question is how does this oil protect the engine in hot climate - 40-45°C? Bergos
Post #725372 25th Aug 2018 7:55pm
Bluest
If you are using a quality one, like Motul Specific 913D, probably fine. I would certainly stay away from the cheaper ones if you are running extreme conditions. Did LR ever specify a different grade hotter climates? 2007 110 TDCi Station Wagon XS
Post #725374 25th Aug 2018 7:57pm
Naks
see my sig --
Post #725393 25th Aug 2018 10:52pm
Caterham
best I've managed on a standard 110xs with remap is 7.037ltr / 100km (ie 40mpg)
in terms of economy speed is the work of the devil, on need to be cruising at about 80-85kmh. Thumbs Up
Post #725425 26th Aug 2018 11:07am
Hal
Over the last 12 months, 6000 miles, my 2011 110 station wagon has averaged out at 29.4 imperial mpg = 9.6 l/100km. That's with standard spec oils, winch, guards, 100kg of stuff in the back, over all sorts of driving inc. light towing., green lane, motorway long distance, whatever.
But every individual fill-up is different, depends what I've been doing.
Post #725454 26th Aug 2018 2:21pm
pme
United Kingdom 2007 Defender 90 Puma 2.4 SW Tonga Green
Same as Hal, long term average over 15000km 10l/100km and the hill here are quite big
Post #725664 27th Aug 2018 5:08pm
