Home > Puma (Tdci) > Whats missing?
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Whats missing?
Just came to wash the screen and only succeeded in washing the bonnet!
I assume the washer jet/nozzle is absent - can this part from Paddocks be used/adapted without taking the dash out?
Thanks Richard
Defender 90 SVX
Post #725019 23rd Aug 2018 12:25pm
Yes, you can do it by removing just the centre panel, but it is fiddly.
Post #725069 23rd Aug 2018 6:27pm
Martin
Site Admin
Worth buying a decent quality one, the pattern ones can be pants.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #725072 23rd Aug 2018 6:33pm
The Optimill one is nice ! Laughing
Post #725085 23rd Aug 2018 7:17pm
zsd-puma
You can take the radio out and the centre section with all the switches on (it only takes 5 min to remove).
You also need to remove the metal support behind the radio (just held with trim clips).
It's not a hard Job to do. It does help a lot if you have someone to hold the outside while you do the nut up.
Post #725089 23rd Aug 2018 7:44pm
muddypaws
Thanks chaps - didn't know whether the washer came apart to avoid undoing the centre console.
I have had it out before when I put the temp gauge in though so should be a breeze this time Rolling Eyes Richard
Defender 90 SVX
Post #725127 23rd Aug 2018 10:48pm
zsd-puma
Theoretically yes it does come apart. Land Rover sell the outer part on its own, but I seem to remember it was more expensive than buying the whole jet and then there is the chance it will just fall off or the remaining part will break when you try to fit it. In which case you end up buying the whole jet anyway! Laughing
It's not a big job to pop the middle of the dash out and change it. I'd say it's only about 30 min to do the whole job from start to finish.
Post #725131 23rd Aug 2018 11:20pm
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
hi there was an article in LROi June issue showing how to upgrade to Optimill with comprehensive instructions with pictures showing how to access the old system
Post #725162 24th Aug 2018 8:22am
NickMc
Strongly agree with Martin buy the cheap one and you’ll be doing it again soon- waste of time.
Post #725310 24th Aug 2018 9:38pm
ARC99
I had one replaced a couple of winters ago. Land Rover had stopped selling the jet part and it was no longer listed on the parts list I had to buy a complete unit and gently split the unit the super glue the jet part to the remaining original. Don't make old people mad.
Richard
Post #725611 27th Aug 2018 11:01am
