![]() | Home > Puma (Tdci) > Whats missing? |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056
Yes, you can do it by removing just the centre panel, but it is fiddly.
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6736
Worth buying a decent quality one, the pattern ones can be pants.
1988 90 Td5 NAS soft top
2015 D90 XS SW |
The Optimill one is nice !
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
You can take the radio out and the centre section with all the switches on (it only takes 5 min to remove).
You also need to remove the metal support behind the radio (just held with trim clips). It's not a hard Job to do. It does help a lot if you have someone to hold the outside while you do the nut up. |
| muddypaws Member Since: 22 Jan 2013 Location: Leicestershire Posts: 122
Thanks chaps - didn't know whether the washer came apart to avoid undoing the centre console.
I have had it out before when I put the temp gauge in though so should be a breeze this time Defender 90 SVX |
Theoretically yes it does come apart. Land Rover sell the outer part on its own, but I seem to remember it was more expensive than buying the whole jet and then there is the chance it will just fall off or the remaining part will break when you try to fit it. In which case you end up buying the whole jet anyway!
It's not a big job to pop the middle of the dash out and change it. I'd say it's only about 30 min to do the whole job from start to finish. |
| Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 202
hi there was an article in LROi June issue showing how to upgrade to Optimill with comprehensive instructions with pictures showing how to access the old system
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
Strongly agree with Martin buy the cheap one and you’ll be doing it again soon- waste of time.
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831
I had one replaced a couple of winters ago. Land Rover had stopped selling the jet part and it was no longer listed on the parts list I had to buy a complete unit and gently split the unit the super glue the jet part to the remaining original. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to Richard |
| All times are GMT |
