![]() | Home > Puma (Tdci) > Help I am stuck! Fridge drained the battery. Can’t start |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
What you can try is take off connections on the battery and touch the 2 cables one or two seconds to make a reset. Before take the good action with the key to try avoid the alarm to go. Hope it will help. If not be sure the the battery of your fob is good Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
You need to charge the battery. Jump starting will usually get a car going if there is some life in the battery, but if the battery is completely dead then you have problems.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21020 ![]() ![]() |
When battery is sorted out be sure to press the fob with the doors closed multiple times until the lights flash and the alarm light on the dash slows from a rapid flash.
You should then be good to go, you do however need the battery fully charged or a replacement. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 238 ![]() ![]() ![]() |
thank you all.
Charged battery. Removed earth from battery.. Horns and alarm went off Put key and pushed buttons. alarm went off Clossed door and pushed the buttons. After a couple of times the central locks worked again and could start.. Pfff. |
Good job.
![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
