Home > Puma (Tdci) > Help I am stuck! Fridge drained the battery. Can’t start
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
Hi left the fridge in 2 days and forgot it. Embarassed
Battery was complete flat.
Tried to start with jumpstarters but alarm went off and couldn’t disarm with the fob.
Put the key in the starter switch and after a while the alarm stopped.
When i start the engine it dies immediately.
Reloaded the battery last night, but fob not working.
The only reaction i get is when the key is in position 2 and i push the lock button. It bleeps the horn 2 times (no lights).
I need to go. Please advice what to do.
Puma 130 2.2 MY 2012
Post #719769 26th Jul 2018 7:31am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
What you can try is take off connections on the battery and touch the 2 cables one or two seconds to make a reset.
Before take the good action with the key to try avoid the alarm to go.
Hope it will help.
If not be sure the the battery of your fob is good
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #719805 26th Jul 2018 11:04am
zsd-puma
You need to charge the battery. Jump starting will usually get a car going if there is some life in the battery, but if the battery is completely dead then you have problems.
Post #719810 26th Jul 2018 11:16am
When battery is sorted out be sure to press the fob with the doors closed multiple times until the lights flash and the alarm light on the dash slows from a rapid flash.
You should then be good to go, you do however need the battery fully charged or a replacement. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #719820 26th Jul 2018 1:20pm
TopQ1967
thank you all.
Charged battery.
Removed earth from battery.. Horns and alarm went off
Put key and pushed buttons.
alarm went off
Clossed door and pushed the buttons.
After a couple of times the central locks worked again and could start..
Pfff.
Post #720063 28th Jul 2018 12:27pm
Good job. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #720070 28th Jul 2018 1:02pm
