|  | Home > Technical > Lock / ignition |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142      | A main agent should have all the details on their data base of your key numbers just pop in and ask them to look up the key numbers for you. Replacements though cost an arm and a leg For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
 http://www.youtube.com/user/conwy1 | ||
|  25th Jul 2018 1:38pm |
| NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 291      | My Ignition Lock is being replaced today under warranty, similar symptoms, sometimes I would spend 5 minutes trying to get it to turn, most frustrating for the drivers behind me in the Fuel queue.
 Being replace with an assembly using the same lock codes hopefully or its back for hem to replace all of the locks so that I only need the one key. NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive | ||
|  25th Jul 2018 2:53pm |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720      | Try a bit of spray grease in the locks. (not the white stuff)
 Are they original keys? or has someone had some copies made? | ||
|  25th Jul 2018 6:36pm |
| Phid Member Since: 25 May 2018 Location: Dorset Posts: 85    | Thanks all
 They are both original keys. I will get some spray grease as you suggest and give that a try. | ||
|  25th Jul 2018 7:04pm |
| mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109      | Just get a new lock set fitted I’m on my second set they are like chocolate | ||
|  25th Jul 2018 7:06pm |
| Phid Member Since: 25 May 2018 Location: Dorset Posts: 85    | Changing barrels looks a bit more of a faf on mine - there is no screw that can simply be taken out as far as I can see.
 Is it straightforward? | ||
|  25th Jul 2018 7:07pm |
| mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109      | I didn’t do mine | ||
|  25th Jul 2018 7:09pm |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | I can thoroughly recommend graphite powder. I had a sticky lock barrel on my old 90 and it transformed it. Because it's a dry lubricant, it doesn't attract dirt either.
   Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia | ||
|  25th Jul 2018 9:02pm |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720      | for graphite powder you can also get a pencil and shave off some of the lead with a knife.
 But some bottles come mixed with alcohol, so you can apply it more easily, the alcohol evaporates and leaves the graphite behind. | ||
|  25th Jul 2018 9:05pm |
| Phid Member Since: 25 May 2018 Location: Dorset Posts: 85    | That’s great thanks - maybe cleaner than the spray on grease
 Cheers | ||
|  25th Jul 2018 9:24pm |
| Blacksheep Member Since: 10 Dec 2017 Location: Highlands Posts: 190  |
 Agree with lra, bought mine from Amazon, it transformed my ignition lock. Time is precious, waste it wisely... Defender 90 D200 | ||
|  26th Jul 2018 6:27am |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | Can't remember where I bought mine but the bottle is as the picture. It works as a puffer and the fine nozzle makes it very easy to apply. I was so impressed that I went round and did all of the house door locks, too. Darren
|  26th Jul 2018 7:14am |
| Phid Member Since: 25 May 2018 Location: Dorset Posts: 85    | Based on this very positive feedback I have ordered some from Amazon Prime so should have the results by the weekend! | ||
|  26th Jul 2018 7:51am |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
