Home > Technical > Lock / ignition
Phid
Lock / ignition
I have an 07 puma XS with central locking.
I have two door/ignition keys and neither seem to work consistently.
One cannot lock the drivers door but is otherwise ok.
The other is sticky to get in but will lock and sometimes struggle to unlock the drivers door. It’s also sometimes a bit sticky in the ignition.
The fact that they’re operating differently suggests key rather than barrel is worn - but I’m not sure. The rear door lock is fine with both keys indicating it could be the drivers door barrel that is worn. Or both.
Can you get replacement keys in the first instance and/or matching barrels and keys? I would prefer to not change the ignition barrel and would prefer to have one key for ignition and doors. How do you get key number or reference if so?
Thanks
Post #719655 25th Jul 2018 2:20pm
gilarion
A main agent should have all the details on their data base of your key numbers just pop in and ask them to look up the key numbers for you. Replacements though cost an arm and a leg For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #719656 25th Jul 2018 2:38pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
My Ignition Lock is being replaced today under warranty, similar symptoms, sometimes I would spend 5 minutes trying to get it to turn, most frustrating for the drivers behind me in the Fuel queue.
Being replace with an assembly using the same lock codes hopefully or its back for hem to replace all of the locks so that I only need the one key. NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #719665 25th Jul 2018 3:53pm
zsd-puma
Try a bit of spray grease in the locks. (not the white stuff)
Are they original keys? or has someone had some copies made?
Post #719698 25th Jul 2018 7:36pm
Phid
Thanks all
They are both original keys.
I will get some spray grease as you suggest and give that a try.
Post #719706 25th Jul 2018 8:04pm
mick
Just get a new lock set fitted I’m on my second set they are like chocolate
Post #719707 25th Jul 2018 8:06pm
Phid
Changing barrels looks a bit more of a faf on mine - there is no screw that can simply be taken out as far as I can see.
Is it straightforward?
Post #719708 25th Jul 2018 8:07pm
mick
I didn’t do mine
Post #719710 25th Jul 2018 8:09pm
I can thoroughly recommend graphite powder. I had a sticky lock barrel on my old 90 and it transformed it. Because it's a dry lubricant, it doesn't attract dirt either.
 Darren
Post #719734 25th Jul 2018 10:02pm
zsd-puma
for graphite powder you can also get a pencil and shave off some of the lead with a knife.
But some bottles come mixed with alcohol, so you can apply it more easily, the alcohol evaporates and leaves the graphite behind.
Post #719738 25th Jul 2018 10:05pm
Phid
That’s great thanks - maybe cleaner than the spray on grease
Post #719742 25th Jul 2018 10:24pm
Blacksheep
Agree with lra, bought mine from Amazon, it transformed my ignition lock. Time is precious, waste it wisely...
Defender 90 D200
Post #719768 26th Jul 2018 7:27am
Can't remember where I bought mine but the bottle is as the picture. It works as a puffer and the fine nozzle makes it very easy to apply. I was so impressed that I went round and did all of the house door locks, too. Darren
Post #719775 26th Jul 2018 8:14am
Phid
Based on this very positive feedback I have ordered some from Amazon Prime so should have the results by the weekend!
Post #719784 26th Jul 2018 8:51am
