Home > Maintenance & Modifications > Maybe seen before but hopefully useful......
Vitesse
 2015 90 XS Santorini Black
Post #718210 17th Jul 2018 1:37pm
Mo Murphy
That's a really good tip if it works !
50 Shades of Pennine Grey
Post #718223 17th Jul 2018 3:26pm
Yes it works, I have been using screws in those clips for years, although I have never had any trouble knocking the plastic peg in either. The main advantage is that the clips are much easier to remove and you don't lose the plastic peg.
Post #718245 17th Jul 2018 6:16pm
zsd-puma
No I don't get his point about knocking the peg in either.
It would reduce the chances of wrecking the clip when removing them mind you.
New trim clips aren't expensive either, but would be good for getting out of trouble on a Sunday afternoon.
Post #718269 17th Jul 2018 7:54pm
Cupboard
you can reuse them if you don't lose the little plastic peg!
Post #720615 31st Jul 2018 9:15am
zsd-puma
You can normally reuse most of them anyway.
They're about £1.50 for a pack of 10 from Britpart, so not exactly expensive to replace, cheaper than buying stainless screws. It's not as if they get removed often.
Post #720672 31st Jul 2018 1:10pm
