![]() | Home > Maintenance & Modifications > Maybe seen before but hopefully useful...... |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 406 ![]() ![]() ![]() |
2015 90 XS Santorini Black
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
Yes it works, I have been using screws in those clips for years, although I have never had any trouble knocking the plastic peg in either. The main advantage is that the clips are much easier to remove and you don't lose the plastic peg.
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
No I don't get his point about knocking the peg in either.
It would reduce the chances of wrecking the clip when removing them mind you. New trim clips aren't expensive either, but would be good for getting out of trouble on a Sunday afternoon. |
you can reuse them if you don't lose the little plastic peg!
You can normally reuse most of them anyway.
They're about £1.50 for a pack of 10 from Britpart, so not exactly expensive to replace, cheaper than buying stainless screws. It's not as if they get removed often. |
