Home > Maintenance & Modifications > Is the Aluminium Body Panels Earthed
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I'm installing a SUB behind the cubby box of my PUMA and need a earth in this vacinity. There is some Bolts close by holding body pannels together behind the box. Will this be earthed?? I dont feel like running a designated earth into the battery box. Although I have to do this for power lead to the sub already...
Post #66865 11th Apr 2011 7:39am
leeds
Whilst the Ali panels will be 'earthed' to some extent you could be just saving a problem up for yourself later in life.
In long run it is much cheaper and easier to run all auxiliary negatives back to the battery via a common negative bus bar in an auxiliary fusebox if need be.
Last week saw a 90 where front aux spots not working. Cause of problem was steel bolt 'earth' mounted on Ali inner wing! New cable run from battery negative, problem solved.
HTH
Brendan
Post #66867 11th Apr 2011 8:02am
dgardel
Italy
For limit the galvanic corrosion risk, it is better to go to the steel Frame! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #66869 11th Apr 2011 8:29am
