![]() | Home > Maintenance & Modifications > Is the Aluminium Body Panels Earthed |
Whilst the Ali panels will be 'earthed' to some extent you could be just saving a problem up for yourself later in life.
In long run it is much cheaper and easier to run all auxiliary negatives back to the battery via a common negative bus bar in an auxiliary fusebox if need be. Last week saw a 90 where front aux spots not working. Cause of problem was steel bolt 'earth' mounted on Ali inner wing! New cable run from battery negative, problem solved. HTH Brendan |
For limit the galvanic corrosion risk, it is better to go to the steel Frame! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
