Home > Maintenance & Modifications > Lightforces- quick question
fordy103
2010 Defender 90 Puma 2.4 HT Zermatt Silver
Currently fitting some Lightforce 170 ( a pair) to the front of my landy, and i was wondering what size fuses to use? Im using 40 amp relays for each and some 27 amp wiring, so that should be sufficient.
Any advice ?
James
Post #66841 10th Apr 2011 7:56pm
I run two 100w each Roo Lites on 20A so i would go with that. Or 25A if you feel the need too. If my memory serves me well i thought 100w bulb uses roughly 8 amps so my two use 16 - 17A hence 20A fuse. Check your bulb wattage rating Thumbs Up
Post #66842 10th Apr 2011 8:02pm
Maverick
Scotland 1996 Defender 90 300 Tdi CSW Alpine White
Is it not illegal to use 100W bulbs in spotlights on the UK roads? Ben
Rebuilt 1996 black/white Defender 90 300 TDi
Post #66845 10th Apr 2011 8:13pm
fordy103
this sounds retarded, but im assuming the bulb wattage rating would be stamped on the bulb itself right?
Post #66846 10th Apr 2011 8:19pm
BigRuss
As a head light yes but not for aux lights as they shouldn't be on when another vehicle is coming towards you on a road. Thumbs Up Russell
2011MY 110 XS USW Black
Post #66850 10th Apr 2011 8:38pm
Maverick
Excellent, thanks Russ! I don't have to change my spotlight bulbs! Very Happy Ben
Post #66852 10th Apr 2011 9:10pm
leeds
Lightforce 170 lights use a 12V 100 watt Xenophot bulb
100 watt/12 volts = 8.5 amps each So minimum fuse per bulb = 10 amps
Details can be found HERE
HTH
Brendan
Post #66856 10th Apr 2011 9:49pm
Just the answer that was needed! ^^^^^ Thumbs Up Mr. Green
Post #66883 11th Apr 2011 12:38pm
