![]() | Home > Maintenance & Modifications > Lightforces- quick question |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
I run two 100w each Roo Lites on 20A so i would go with that. Or 25A if you feel the need too. If my memory serves me well i thought 100w bulb uses roughly 8 amps so my two use 16 - 17A hence 20A fuse. Check your bulb wattage rating
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 ![]() ![]() ![]() |
Is it not illegal to use 100W bulbs in spotlights on the UK roads? Ben
Rebuilt 1996 black/white Defender 90 300 TDi |
fordy103 Member Since: 22 Dec 2010 Location: preston lancs Posts: 85 ![]() ![]() |
this sounds retarded, but im assuming the bulb wattage rating would be stamped on the bulb itself right?
As a head light yes but not for aux lights as they shouldn't be on when another vehicle is coming towards you on a road. ![]() 2011MY 110 XS USW Black |
Excellent, thanks Russ! I don't have to change my spotlight bulbs!
![]() Rebuilt 1996 black/white Defender 90 300 TDi |
Lightforce 170 lights use a 12V 100 watt Xenophot bulb
100 watt/12 volts = 8.5 amps each So minimum fuse per bulb = 10 amps Details can be found HERE HTH Brendan |
Just the answer that was needed! ^^^^^
