Home > Maintenance & Modifications > Central lock on rear door
mark13
United Kingdom 2004 Defender 90 2.5 TD HT Cairns Blue
Has anybody worked out a neat way of connecting an actuator to the rear door of a defender for central locking that does not involve having bits of rod poking out of the door card?
Post #715238 29th Jun 2018 10:35pm
grafty99
Only way it can be done really. A mudstuff rear door card would hide it though Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #715242 29th Jun 2018 10:53pm
zsd-puma
fit one of the later type one piece rear doors - the whole door is far superior to the earlier ones, they're galvanised steel as standard for a start.
Post #715256 30th Jun 2018 12:58am
mark13
Unfortunately mine is a 2004 TD5 so the Mud Stuff will not fit. I do not want to go to the cost of replacing the door plus my rear door is mint absolutely no rust on it anywhere.
Does anybody have a second hand lock from for a rear door that I can buy? I might break into one and see what can be done!
Post #715260 30th Jun 2018 6:13am
grafty99
In that case it should have the later pressed steel door. Just buy the genuine parts and fit them.
The rod comes out of the top of the lock to a swivel, then goes across the door. 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #715270 30th Jun 2018 8:06am
grafty99
That's the standard setup post 2002
1990 Vogue SE
Post #715271 30th Jun 2018 8:15am
mark13
Is this the right part for a 2004 TD5 rear door to central locking (rounded corner windows)
https://www.sp-4x4.com/ProductDetails.asp?...p;CartID=1
These guys seem considerably cheaper than the other shops, should I be worried about quality?
I do not surpose anybody knows the part number of the plastic bracket (white thing in picture) that goes up the top that the 2 link bars connect to?
Post #715278 30th Jun 2018 9:34am
zsd-puma
Post #715295 30th Jun 2018 11:52am
mark13
Thank you Very Happy
Post #715300 30th Jun 2018 12:52pm
