![]() | Home > Maintenance & Modifications > Central lock on rear door |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
Only way it can be done really. A mudstuff rear door card would hide it though
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
fit one of the later type one piece rear doors - the whole door is far superior to the earlier ones, they're galvanised steel as standard for a start.
mark13 Member Since: 16 Apr 2018 Location: Essex Posts: 56 ![]() ![]() ![]() |
Unfortunately mine is a 2004 TD5 so the Mud Stuff will not fit. I do not want to go to the cost of replacing the door plus my rear door is mint absolutely no rust on it anywhere.
Does anybody have a second hand lock from for a rear door that I can buy? I might break into one and see what can be done! |
In that case it should have the later pressed steel door. Just buy the genuine parts and fit them.
The rod comes out of the top of the lock to a swivel, then goes across the door. 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
That's the standard setup post 2002
![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Is this the right part for a 2004 TD5 rear door to central locking (rounded corner windows)
https://www.sp-4x4.com/ProductDetails.asp?...p;CartID=1 These guys seem considerably cheaper than the other shops, should I be worried about quality? I do not surpose anybody knows the part number of the plastic bracket (white thing in picture) that goes up the top that the 2 link bars connect to? |
Thank you
