Home > Technical > Defender as10
smurf500
England 2005 Defender 90 Td5 HT Belize Green
Defender as10
Help please,I’m trying to fit the as10 into my defender so I have central locking,the problem I have I can’t get the as10 to communicate with the ecu,I have a nanocom,can get everything working,but when I go to start it it turns over but won’t start as soon as I connect the old as10 she fire straight away.cheers 2005 td5 90
Post #715139 29th Jun 2018 11:31am
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
I don't know about the coding side of things but others maybe able to help
However I recently added central looking to my defender via soldering in an additional relay. The guy who supplied is here and provided instructions... it cost about 8 quid and was dead easy.
https://www.ebay.co.uk/itm/Land-Rover-10AS...xy8HlScq7W
Might be another option if you get stuck
Post #715149 29th Jun 2018 1:17pm
dorsetsmith
ECM need to lean new code from AS10
Post #715154 29th Jun 2018 1:42pm
JOW240725
If you can't get it going speak with Dan Padmore from Pace Automotive. Dan is away on holiday at the moment though. James
Instagram @suffolk_rovers
Post #715180 29th Jun 2018 5:12pm
zsd-puma
Do you actually need to program the new 10AS?
The old 10AS unit should still have the components to control the central locking, you just need to tell the 10AS module that you now have central locking fitted. It may even have it activated by default and by plugging in the central locking wiring it just works.
Post #715251 29th Jun 2018 11:58pm
