![]() | Home > Technical > Defender as10 |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
I don't know about the coding side of things but others maybe able to help
However I recently added central looking to my defender via soldering in an additional relay. The guy who supplied is here and provided instructions... it cost about 8 quid and was dead easy. https://www.ebay.co.uk/itm/Land-Rover-10AS...xy8HlScq7W Might be another option if you get stuck |
ECM need to lean new code from AS10
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7944 ![]() ![]() ![]() |
If you can't get it going speak with Dan Padmore from Pace Automotive. Dan is away on holiday at the moment though. James
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Do you actually need to program the new 10AS?
The old 10AS unit should still have the components to control the central locking, you just need to tell the 10AS module that you now have central locking fitted. It may even have it activated by default and by plugging in the central locking wiring it just works. |
