Home > Puma (Tdci) > Dashboard torx screw
Bluest
Could someone tell me the part number for the torx screw on the top of the dash in the centre? 2007 110 TDCi Station Wagon XS
Post #706678 12th May 2018 12:01am
I could try but I'd probably end up talking a load of Macintosh.
I'll get my anorak... Darren
Post #706681 12th May 2018 12:18am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Have a look here:-
https://www.landroverworkshop.com/diagrams...acia_45040
Same as item 15. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #706687 12th May 2018 6:58am
Bluest
Mr. Green 2007 110 TDCi Station Wagon XS
Post #706700 12th May 2018 8:23am
Bluest
nosnibod wrote:
Have a look here:-
Same as item 15.
It the the top centre hole close the windscreen. Doesn’t look like there is a screw in there, maybe I’m not missing one after all. 2007 110 TDCi Station Wagon XS
Post #706702 12th May 2018 8:49am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
- n° 10 = 15 : SCREW, 4.8 X 25MM, TORX - Part number: FYP000341
 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #706703 12th May 2018 8:58am
Bluest
Those are the ones for the centre panel, don’t need them. I thought I was missing one front the very top centre of the dash at the bottom of the windscreen. There is a hole and recess there that looks like it should have a screw in. However, on that diagram you can just make out the recess but no screw in indicated. 2007 110 TDCi Station Wagon XS
Post #706705 12th May 2018 9:02am
nosnibod
There should be one in there; it threads into one of those plastic captive nuts attached to the bulkhead. Dave
Post #706706 12th May 2018 9:07am
There should be a screw there, although I can't tell you the p/n. My memory suggests it may be the same as the 2 on the grab handle and the 2 below the binnacle but I can't be certain.
Post #706707 12th May 2018 9:12am
Theater
The screw on the centre of the dash is the same as the items n 10 and 15
 Marco
Post #706711 12th May 2018 10:13am
nosnibod
I've just nipped out and checked.
Part 15 is this one with a course thread and a painted head:-
And here is the screw behind the centre of the dash - I did unscrew the centre one and then forgot to take a photo before putting the satnav bracket back but it's the same type:-
So you need part number FYP000341.
On ones either side of the grab handle and either side of the instrument binnacle are different - they have a M6 thread because they screw into the big tubular support behind the dash. Visually you can tell the difference because they are plated and not painted, like this:-
 Dave
Post #706712 12th May 2018 10:14am
