![]() | Home > Puma (Tdci) > Dashboard torx screw |
I could try but I'd probably end up talking a load of Macintosh.
I'll get my anorak... Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
Have a look here:-
https://www.landroverworkshop.com/diagrams...acia_45040 Same as item 15. Dave Green Goddess - 1998 Defender 110 300tdi |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4292 ![]() ![]() ![]() |
It the the top centre hole close the windscreen. Doesn’t look like there is a screw in there, maybe I’m not missing one after all. 2007 110 TDCi Station Wagon XS |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
![]() Click image to enlarge - n° 10 = 15 : SCREW, 4.8 X 25MM, TORX - Part number: FYP000341 ![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Those are the ones for the centre panel, don’t need them. I thought I was missing one front the very top centre of the dash at the bottom of the windscreen. There is a hole and recess there that looks like it should have a screw in. However, on that diagram you can just make out the recess but no screw in indicated. 2007 110 TDCi Station Wagon XS
There should be one in there; it threads into one of those plastic captive nuts attached to the bulkhead. Dave Green Goddess - 1998 Defender 110 300tdi |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
There should be a screw there, although I can't tell you the p/n. My memory suggests it may be the same as the 2 on the grab handle and the 2 below the binnacle but I can't be certain.
The screw on the centre of the dash is the same as the items n 10 and 15
![]() Click image to enlarge ![]() Click image to enlarge Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 Last edited by Theater on 12th May 2018 10:37am. Edited 2 times in total |
I've just nipped out and checked.
Part 15 is this one with a course thread and a painted head:- ![]() Click image to enlarge And here is the screw behind the centre of the dash - I did unscrew the centre one and then forgot to take a photo before putting the satnav bracket back but it's the same type:- ![]() Click image to enlarge So you need part number FYP000341. On ones either side of the grab handle and either side of the instrument binnacle are different - they have a M6 thread because they screw into the big tubular support behind the dash. Visually you can tell the difference because they are plated and not painted, like this:- ![]() Click image to enlarge Dave Green Goddess - 1998 Defender 110 300tdi |
