Home > Td5 > Standard eu3 fuel map needed
Lewis barclay
United Kingdom 2004 Defender 90 Td5 XS CSW Willow Green
Hello new member here first post
Due to new mot regulations im looking at putting my 2004 td5 defender fuel map back to standard for its mot at present its tuned but is a little smokey
I have a nanocom and multiple map files both standard and tuned. But sadly other than the tuned map file i paid for all other files are eu2 and the car dosent run right .so in essence im on the blag for a standard eu3 map file .im more than happy to share my tuned files in return .
Hope you can help
Many thanks in advance
Lew
Post #706174 9th May 2018 9:35am
Clive
Hi and welcome.
Not sure if you're aware of it but you can download the "Map Wizard" utility from the Nanocom site @ https://nanocom-diagnostics.com/downloads
The files are arranged by order of vehicle and ECU type, the newest ones that I can see are dated Nov 2002 and for the NNN500020 ECU, I'm not so sure there was any further development after that or when the EU3 compliance came in.
Also, so far as I know, the .TUN files contain the VIN and can only be applied to the vehicle it was written for whereas the .MAP files are freely useable.
Post #706203 9th May 2018 1:35pm
Lewis barclay
Hi clive thanks for the speedy reply ..
Ive used that map wizzard for years and its great unfortunately the stock map files it generates are all eu2 specific and sadly it throws up an awful lot of fault codes and the car runs like a sack of poop
Just hoping some one either had a stock map from when they have upgrated thr .map file or if anyone has a nanocom and a td5 running a stock eu3 fuel map that they could read and ppst for me ..
Thanks lew
Post #706204 9th May 2018 1:39pm
bankz5152
Why not just take it down and ask for it to be tested and see if it passes? May be fine.
Post #706214 9th May 2018 2:43pm
Lewis barclay
Hi bankz no doubt it possibly would as garage owner is a close friend its more a case of being able to do it legit as its a little bit smokey .. if anyones local to me im quite happy to come and meet and read a standard fuel map with the nanocom.
Post #706216 9th May 2018 3:42pm
bankz5152
lol i know. I meant take it down before MOT time, have them check its OK. If it is then no need to worry!
Post #706219 9th May 2018 4:14pm
mk1collector
If it's black smoke it could be a split intercooler or hoses (especially if you have an allisport intercooler I've found) so you may not have to get rid of the map. Ray
My build thread
Post #706220 9th May 2018 4:14pm
bankz5152
Why especially if ita allisport?
Post #706221 9th May 2018 4:15pm
mk1collector
There are many reports of allisport intercoolers splitting all over the net including my own and claytons on here recently. Ray
My build thread
Post #706222 9th May 2018 4:17pm
Lewis barclay
I had an issue a while ago where i lost about 20% boost put this down to an aging turbo as its done 156k couldnt find any leak on sytem tested this by removing boost hose from turbo blocking it and stalling the engine. So as a result just cranked the waste gate to get the boost back up boost sitting comfortable just below the over boost level so about 1.36 or 240 on kp no other issue but still black smoke on pull away and on wide open i appreciate it will pas the emissions test Wink but its some times nice to go back to stock from time to time makes the retune feel good again after a period of flat as a fart standard
Post #706223 9th May 2018 4:22pm
bankz5152
Hmmm while it maye have happened to you and the other fella mines been in for 2 years i think now without issue. My 110 is driven hard on and off road thru muck and sand alike and still going strong! Not to mention the 4 people I know using them in Ultra4 and other rally raid events without issue. Plus lifetime guarentee, splits you get a nee one foc. Cant complain! Swings n round abouts I guess.
Post #706228 9th May 2018 4:44pm
Lewis barclay
Standard intercooler not alisport im not made of money lol
Post #706232 9th May 2018 5:05pm
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
Thanks lew
I am also looking for the map, may i suggest you write in the new injectors. You may have to open the rocker cover, and copy the code on the top of the injectors, write them to the ecu, and check to see if that works
Post #706893 13th May 2018 2:31pm
Lewis barclay
Hi naf thanks for the advice sadly this has already been done the joys of owning a nanocom i have some local landrover clubs near me so might pop and see if some one will allow me to copy there fuel map.
Post #706910 13th May 2018 4:12pm
Naf
In the wizard did you try and use svlor005-svpnt006
It should be the correct Eu3 as its for a 2002 td5 110 for the rest of the world...
Post #707076 14th May 2018 12:04pm
