Home > Technical > Tdi Breakdown Help! Battery light/alternator
mini Anaconda
Hello,
I'm not overly technical so looking for some advice, when I turn the engine off on my 200tdi, the battery light will not turn off. The only way to turn it off is to disconnect the battery. When I put the ignition on the light does not illuminate like it usually would, but I have checked with a multimeter and the battery is charging.
Could it possibly be the ignition switch? I don't want to damage anything by driving home?
P.S. I heard the fanbelt squeal a little bit earlier, it is a little loose but not particularly - maybe just a coincidence?
Many thanks Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #704814 2nd May 2018 4:44pm
steveyorks
England 1993 Defender 90 200 Tdi CSW Barolo Black
I would guess that an alternator fault could be the reason your ignition light is not going off. Might also account for the fan belt squeal.
Post #704818 2nd May 2018 5:09pm
Definitely alternator with those symptoms. Darren
Post #704830 2nd May 2018 5:53pm
VeeTee
Netherlands
Very likely one of the diodes in the alternator has failed. Cheers, Vincent
MySite
Post #704858 2nd May 2018 7:52pm
mini Anaconda
Thanks guys, will order a new one....
I have a Discovery 200tdi in my 90, I'm struggling to understand the difference between a left and right hand fitting? I think left? Question BORG - Bucks & Oxon 4x4 Response Group
Post #704860 2nd May 2018 8:02pm
Retroanaconda
You should be able to just change the rectifier pack, rather than the whole alternator.
Post #704874 2nd May 2018 8:25pm
NickMc
Check the belt is tight first. The switch off problem could be the fuel solenoid in the top on the injector Pump.
Post #704881 2nd May 2018 8:36pm
