![]() | Home > Technical > Tdi Breakdown Help! Battery light/alternator |
| steveyorks Member Since: 08 Apr 2013 Location: west yorkshire Posts: 193
I would guess that an alternator fault could be the reason your ignition light is not going off. Might also account for the fan belt squeal.
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Definitely alternator with those symptoms. Darren
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Very likely one of the diodes in the alternator has failed. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 846
Thanks guys, will order a new one....
I have a Discovery 200tdi in my 90, I'm struggling to understand the difference between a left and right hand fitting? I think left? ![]() |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2789
You should be able to just change the rectifier pack, rather than the whole alternator.
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
Check the belt is tight first. The switch off problem could be the fuel solenoid in the top on the injector Pump.
| All times are GMT |
