Home > Maintenance & Modifications > Bearmach LED number plate light conundrum |
pux146 Member Since: 30 Apr 2018 Location: Wiltshire Posts: 121 |
I have fitted one of these, it fitted straight away with out any problems. 2007 2.4 90 fettled & remapped.
1st May 2018 4:54pm |
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 300 |
I don't know if these are the same, but there is a handy fitting instruction here:
https://www.mudstuff.co.uk/products/electr...-lamp.html |
2nd May 2018 12:52am |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1777 |
Thanks, PUX146.
Thanks Danny but it's different as you cant access the bolts in the Bearmach one as they they are inside the lamp unit which appears to be bonded. Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
2nd May 2018 8:56am |
Could you put up a couple of pics? Ray
2nd May 2018 9:27am |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
Hmm, mine fitted, without the plinth without any issues, just wired them into the existing circuits. |
2nd May 2018 1:31pm |
I'm not exactly sure what to show but: Click image to enlarge |
2nd May 2018 5:49pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
You have taken the screw out of the front? I would guess it’s a standard off the shelf light and they don’t have longer “studs” for the Defender number plate spacer. Maybe they expect you to do away with the “spacer”?!?
2nd May 2018 6:25pm |
I have taken the screw off the front but the light unit itself appears not to come to bits to release the short bolts. It is sold Defender specific so had assumed it would fit with plinth, but I'll ask WildCat who supplied it as their customer service has been good. Not a major issue obviously, but just wanted to get to the bottom of it . . . . . . .
2nd May 2018 6:37pm |
Thats exactly the one I have, fitted perfectly! 2007 2.4 90 fettled & remapped. |
2nd May 2018 7:13pm |
Could you take the gasket off the back and take a pic of the back and a pic of the front Ray
2nd May 2018 7:24pm |
I've just looked up bearmach number plate lights on google and they all look to have the screw on the front, so if yours has, just unscrew it and take the black plastic cover off and the bolts can be removed to put your old longer ones in. Ray
2nd May 2018 7:29pm |
Thanks very much for persevering with this
I have just taken the screw out and I think it is cosmetic. I have taken the nuts off the back. And, the bolts are fixed rigidly in place and I can't get the black cover to separate from the light unit Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
2nd May 2018 7:44pm |
Where the black cover is at the back is there any little tabs to lift up which may be holding the cover on? Ray
2nd May 2018 8:16pm |
Is the foam on the rear thick enough to cover the wires if they don't line up with the hole? 2002 90 Td5 Station Wagon
2nd May 2018 9:40pm |
