Home > Maintenance & Modifications > Bearmach LED number plate light conundrum
CarMan
I ordered a set of smoked rear fog and reverse lights with WIPAC rear number plate light (all LED) from WildCat and they were out of stock of the WIPAC number plate lights so I willingly accepted the substitute Bearmach item as it wasn't branded. They were great to deal with by the way, but are currently away until Monday.
Anyway, I can't work out if I have lost the plot somehow (highly likely btw), but I can't see how to fit the Bearmach number plate light so have reverted to my Bolt-On-Bits one, which I must say appears not to be such nice quality, but looks and works fine.
Fundamentally the problem is the Bearmach light unit appears to be bonded so I can't get the bolts out and they are not nearly long enough to fit through the plinth and into the tub. I did think of fitting it without the plinth direct to the tub but the wiring coming out the back of the lamp prevents that from sitting flush so would mean drilling a new central hole in the tub which I'm not prepared to do Rolling Eyes
Also, it has bullet connectors so have bought the correct Sumitomo connector for the Puma harness.
So, has anyway else fitted this and if so am I missing a trick here Question
If not, soon to be for sale elsewhere in a separate listing in the correct place of course Thumbs Up
Thanks. Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #703502 27th Apr 2018 10:26am
pux146
I have fitted one of these, it fitted straight away with out any problems. 2007 2.4 90 fettled & remapped.
Post #704578 1st May 2018 4:54pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I don't know if these are the same, but there is a handy fitting instruction here:
https://www.mudstuff.co.uk/products/electr...-lamp.html
Post #704700 2nd May 2018 12:52am
CarMan
Thanks, PUX146.
Thanks Danny but it's different as you cant access the bolts in the Bearmach one as they they are inside the lamp unit which appears to be bonded.
Confused Rob
Post #704722 2nd May 2018 8:56am
mk1collector
Could you put up a couple of pics? Ray
My build thread
Post #704726 2nd May 2018 9:27am
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Re: Bearmach LED number plate light conundrum
Thanks.
Hmm, mine fitted, without the plinth without any issues, just wired them into the existing circuits.
Post #704762 2nd May 2018 1:31pm
CarMan
I'm not exactly sure what to show but:
Post #704816 2nd May 2018 5:49pm
NickMc
You have taken the screw out of the front? I would guess it’s a standard off the shelf light and they don’t have longer “studs” for the Defender number plate spacer. Maybe they expect you to do away with the “spacer”?!?
Post #704822 2nd May 2018 6:25pm
CarMan
I have taken the screw off the front but the light unit itself appears not to come to bits to release the short bolts. It is sold Defender specific so had assumed it would fit with plinth, but I'll ask WildCat who supplied it as their customer service has been good. Not a major issue obviously, but just wanted to get to the bottom of it . . . . . . .
Post #704823 2nd May 2018 6:37pm
pux146
Thats exactly the one I have, fitted perfectly! 2007 2.4 90 fettled & remapped.
Post #704834 2nd May 2018 7:13pm
mk1collector
Could you take the gasket off the back and take a pic of the back and a pic of the front Ray
My build thread
Post #704838 2nd May 2018 7:24pm
mk1collector
I've just looked up bearmach number plate lights on google and they all look to have the screw on the front, so if yours has, just unscrew it and take the black plastic cover off and the bolts can be removed to put your old longer ones in. Ray
My build thread
Post #704839 2nd May 2018 7:29pm
CarMan
Thanks very much for persevering with this Thumbs Up
I have just taken the screw out and I think it is cosmetic.
I have taken the nuts off the back.
And, the bolts are fixed rigidly in place and I can't get the black cover to separate from the light unit
Whistle Rob
Post #704841 2nd May 2018 7:44pm
mk1collector
Where the black cover is at the back is there any little tabs to lift up which may be holding the cover on? Ray
My build thread
Post #704849 2nd May 2018 8:16pm
grafty99
Is the foam on the rear thick enough to cover the wires if they don't line up with the hole? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #704884 2nd May 2018 9:40pm
