Home > Maintenance & Modifications > Using Land Rover Switch with KC daylighter Wiring harness?
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I've purchased the KC daylighted Spots that come with it's own witing harness:
http://www.kchilites.com/wp-content/upload...ss_web.pdf
I'm going to use the landrover switch (YUG000540LNF).
But I'm very confused as to how I should wire up that switch. It looks like in the KC wiring diagram the connector from pin5 on the swicth is not there. Can I use the LR wiring diagram but then add that connection from pin5 on the switch to relay pin 87?
http://www.defender2.net/forum/topic552.ht...p;start=15
Post #65476 29th Mar 2011 10:59am
mse
dead simple
Look on here for my or other posts...all you need to do is follow those diagrams and put the switch in place of the diagram switch Mike
Post #65510 29th Mar 2011 5:13pm
Marius
I'm sorted.
Trick is you have to modify thst switch to be an on off switch as per te post I refered to.
Post #65561 30th Mar 2011 6:20am
mse
Marius wrote:
I'm sorted.
The 2nd lighting switch is an on off switch Shocked are you using the correct switch??
Glad you sorted it Mike
Post #65568 30th Mar 2011 7:47am
