![]() | Home > Maintenance & Modifications > Using Land Rover Switch with KC daylighter Wiring harness? |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
I've purchased the KC daylighted Spots that come with it's own witing harness:
http://www.kchilites.com/wp-content/upload...ss_web.pdf I'm going to use the landrover switch (YUG000540LNF). But I'm very confused as to how I should wire up that switch. It looks like in the KC wiring diagram the connector from pin5 on the swicth is not there. Can I use the LR wiring diagram but then add that connection from pin5 on the switch to relay pin 87? http://www.defender2.net/forum/topic552.ht...p;start=15 |
I'm sorted.
Trick is you have to modify thst switch to be an on off switch as per te post I refered to. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5101 ![]() ![]() ![]() |
The 2nd lighting switch is an on off switch ![]() Glad you sorted it Mike |
