Home > Maintenance & Modifications > Defender 90 suspension
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Looking for a better ride and slightly stiffer on corners as mine is too soft. Mine
Never had a tow bar fitted from new so was the suspension different to ones with ? My
03 hardtop was far better. I’m looking at bilstein b6 shocks but not sure on what springs to go for ?
Post #697501 31st Mar 2018 8:01pm
mk1collector
Does yours have anti roll bars? If not it's worth fitting them for better cornering. Ray
My build thread
Post #697503 31st Mar 2018 8:09pm
Alextd5
Yes it had the standard anti roll bars. Any worthwhile upgraded to these?
Post #697504 31st Mar 2018 8:11pm
mk1collector
Updated anti rol bars will make a difference to cornering over standard. Are your springs standard from new also? They may be starting to sag if they've been on a while but I suppose you need to decide what you use the defender for, all on road, off road or what percentage roughly of each. Ray
My build thread
Post #697506 31st Mar 2018 8:14pm
mk1collector
If all on road alive do a kit with slightly lower springs bilstein shocks and bigger anti roll bars. Ray
My build thread
Post #697507 31st Mar 2018 8:16pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
The Alive uprated ARB makes a big difference on its own. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #697514 31st Mar 2018 8:38pm
Alextd5
Ideally I wouldn’t want to lower it, even though it’s road use 90% of the time. I have made My mind up with the b6 shocks but not sure on springs. It’s just coming up to 70k so maybe they could do with replacing. But Im looking to get one of the last 16 plate 90’s so this might go depending on whether I can put up with the tdci.
Post #697579 1st Apr 2018 9:14am
