Home > Maintenance & Modifications > Material for building Defender furniture
olivers
2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
I’m looking to build a few storage elements, shelves etc, for the back of my 90. I’m wondering what the best material is for this... furniture board comes to mind, but I have concerns - it’s not the lightest stuff, I’ve seen furniture board shelves sag quite a bit and so on. Hm.
Other ideas? Should be lightweight, reasonably easy to use for the purpose, stable enough for use as shelves or sidewalls, available in a range of sizes. If you’ve done something like this, what did you use?
Oli
Post #697028 29th Mar 2018 7:55pm
Plywood. Weight for weight, it's plenty strong enough, comes in a range of thicknesses, easy to cut, etc. Darren
Post #697037 29th Mar 2018 8:26pm
macfrank
These PVC-coated plywood is really great:
https://translate.google.com/translate?sl=...mp;act=url
(sorry, haven't got a UK source)
I've used 7mm for furniture walls and 10mm for table tops and lids (to stand on).
Post #697224 30th Mar 2018 3:54pm
LiftedDisco
Try something like Dibond or ACM (Aluminium Composite Material) which is available in various colours etc
Post #697250 30th Mar 2018 5:47pm
olivers
Thanks for the ideas! I’ll look into it some more... off now for a bit of Easter relaxation in Yorkshire, but there should be time for some online research!
I was wondering about required thickness, so thanks to macfrank for mentioning it. I really don’t want those shelves to be sagging after a little while... due to lack of experience, I tend to overcompensate when I select wood for a purpose - not always a bad thing, but I want to keep an eye on weight for this project.
Post #697500 31st Mar 2018 7:52pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
http://www.wisaplywood.com/Products/produc...fault.aspx
A phenolic injected/covered ply sheet is the most universal material for what you want to do.
Post #697549 31st Mar 2018 10:34pm
