![]() | Home > Maintenance & Modifications > Material for building Defender furniture |
Plywood. Weight for weight, it's plenty strong enough, comes in a range of thicknesses, easy to cut, etc. Darren
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1125 ![]() ![]() ![]() |
These PVC-coated plywood is really great:
https://translate.google.com/translate?sl=...mp;act=url (sorry, haven't got a UK source) I've used 7mm for furniture walls and 10mm for table tops and lids (to stand on). |
LiftedDisco Member Since: 17 Aug 2014 Location: Towcester Posts: 357 ![]() ![]() |
Try something like Dibond or ACM (Aluminium Composite Material) which is available in various colours etc
olivers Member Since: 19 Jan 2012 Location: Southern Scotland Posts: 115 ![]() ![]() |
Thanks for the ideas! I’ll look into it some more... off now for a bit of Easter relaxation in Yorkshire, but there should be time for some online research!
I was wondering about required thickness, so thanks to macfrank for mentioning it. I really don’t want those shelves to be sagging after a little while... due to lack of experience, I tend to overcompensate when I select wood for a purpose - not always a bad thing, but I want to keep an eye on weight for this project. |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
http://www.wisaplywood.com/Products/produc...fault.aspx
A phenolic injected/covered ply sheet is the most universal material for what you want to do. |
