![]() | Home > In Car Electronics > Exmoor trim heated seat kit |
| 300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 863
I wired mine into a "bluesea" style split fuse block.
One side is permanently connected to my 2nd battery and the other side is energised via an ignition switched relay (switched positive courtesey of some caravan electrics). The heated seats are on the ignition switched side, I can keep them on as long as the ignition is turned onto the "accessory" position but you can't leave them on if you take the keys out of the ignition. It seems to work for me. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
What year did the wiring come in from LR for heated seats? Mine is a 1999 td5.
If i do have the wires its time to go hunting. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
t was probably the TD5 facelift in 2002. Darren
Cheers LRA - didnt think there was wiring in place.
I did have a thought.....i was thinking that if I used a Voltage sensing relay so the heated seats only work at say 14v then i could use the relay to power the heateed seat loom, the heated mirror kit that I also have to fit and finally kick in the split charge relay (which is fed via trip coming from the radio.) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Got the loom installed. Just enough room under a standard cubby box to put the relays and the wires.
Each loom has 7.5amp fuse so wired both looms together and feed the pair of looms via 27amp cables fed from an 80amp relay that is only active once the engine reaches 14v. (switched by a separate module). I will use the same relay to feed the heated mirror elements when I get around to installing them All I need now is a parcel from Exmoor trim. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Parcel from Exmoor arrived yesterday containing the seat trim kit
Fun will commence when I get a spare weekend 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| All times are GMT |
