Home > Puma (Tdci) > Bumper removal with air-con
TOP5N
to remove the front bumper on my 2015 xs with air-con, do i need to remove the grill...
Chris
Post #691280 5th Mar 2018 10:05pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Yes but it's very easy. You need to remove the body coloured frame, but leave the grille on that.
Two big screws on the sides of the frame, and four small ones along the top you'll see when you open the bonnet. Job jobbed. Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #691285 5th Mar 2018 10:14pm
JOW240725
As above. It's easy, even I have done it.
I've just changed my bumper. Search Youtube I found a really useful video from PowerfulUK I think, shows every step. Really easy after watching it.
The bumper has funny captive nuts on bottom. James
Instagram @suffolk_rovers
Post #691290 5th Mar 2018 10:19pm
JOW240725
Not air con, but remove grille with surround and then follow video  James
Post #691294 5th Mar 2018 10:24pm
TOP5N
Excellent. Thanks
Post #691308 5th Mar 2018 10:58pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
You will probably find the small screws on the top of the grill are rusted through so best replaced with stainless. The bumper bolts retaining plate will also be rusted through, but again stainless or oem replacements are cheap. Check before you start and have replacements ready!
Post #691375 6th Mar 2018 9:51am
Does anyone recall the bumper bolt size? The washers on the top of mine are badly rusted and could do with swapping out for some nice stainless ones.
Post #691439 6th Mar 2018 3:24pm
JOW240725
Bumper bolt kit DA1139
4no. M10 x 120
4no. M10 3mm x 30mm flat washers
4no. plastic head caps
Thumbs Up James
Post #691940 8th Mar 2018 1:50pm
Thanks - off to look for some stainless M10 3mm x 30mm flat washers - the original galv on mine did not last very long.
Post #691960 8th Mar 2018 3:16pm
zsd-puma
I got the Britpart bolt kit, it's decent enough quality, and comes with plastic caps to go over the bolt heads.
If however you don't intend fitting a winch or mounting recovery points on the bumper then stainless is probably the way to go.
Post #691970 8th Mar 2018 3:44pm
Just new stainless washers ordered - couldn't find the exact right size so settled for some Form G A4 ones that come in at M10 x 30mm x 2.5mm from Kays Fasteners.
Post #692001 8th Mar 2018 6:01pm
