Home > Puma (Tdci) > Abs/tc light on
Okan
Switzerland 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Abs/tc light on
Hi!
On my 2.4 one ten puma 2009 abs and tc yellow light is on and doesn't remove. I allready checked abs fuse and it's ok. Checked the two abs sensors and it doesn't change anything. Abs doesn't work. No fault code on the ECU. Any ideas?
best regards
Post #690936 4th Mar 2018 8:27pm
Def Junkie
Hi, were you able to identify the cause? Interested to find out as my 2009 Puma has also developed the same thing. It comes on after about 30 minutes of running and stays on for the redt of the day. Same thing the next day and so on.
Post #692159 9th Mar 2018 12:08pm
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Good day I am with the same problem.
Defender Puma 2008 2.4
Greetings.
Post #692162 9th Mar 2018 12:27pm
Okan
I just solved the problem. For me It was the abs sensors. Just put each sensor inside with a little hammer. We plugued the nanocom and erase the fault code. Have to wait a bit if the fault comes back.
Okan
Post #692266 9th Mar 2018 8:33pm
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
This Censored happens sometimes in my 2007 Def. In my case there is also the red brake icon if I remember well...
Nanocom suggests it's a poor earth.
I've been trying to clean and tighten the earth point but it still happens from time to time. Usually goes off after a restart. Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #695109 21st Mar 2018 2:18am
Simon dlb
Kenya
Could you show or describe where the earth is? Thank you! Puma 2.4 2010
Post #956792 29th Jun 2022 5:38am
Bluest
When you say no fault codes on the ECU, are you able to read the ABS unit fault codes? Not all readers can. When I had those lights it was shuttle valve switch failure on the ABS pump, but that does record a fault code in the ABS system. 2007 110 TDCi Station Wagon XS
Post #956798 29th Jun 2022 8:20am
It's worth noting that the original post is four years old, chaps. Darren
Post #956802 29th Jun 2022 8:58am
