![]() | Home > Puma (Tdci) > Abs/tc light on |
Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 ![]() |
Hi, were you able to identify the cause? Interested to find out as my 2009 Puma has also developed the same thing. It comes on after about 30 minutes of running and stays on for the redt of the day. Same thing the next day and so on.
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 98 ![]() ![]() ![]() |
Good day I am with the same problem.
Defender Puma 2008 2.4 Greetings. |
Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138 ![]() ![]() ![]() |
I just solved the problem. For me It was the abs sensors. Just put each sensor inside with a little hammer. We plugued the nanocom and erase the fault code. Have to wait a bit if the fault comes back.
Okan |
Bergos Member Since: 08 Aug 2015 Location: Somewhere in Portugal Posts: 95 ![]() ![]() ![]() |
This
![]() Nanocom suggests it's a poor earth. I've been trying to clean and tighten the earth point but it still happens from time to time. Usually goes off after a restart. Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
Simon dlb Member Since: 26 Mar 2022 Location: Nairobi Posts: 12 ![]() ![]() |
Could you show or describe where the earth is? Thank you! Puma 2.4 2010
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4325 ![]() ![]() ![]() |
When you say no fault codes on the ECU, are you able to read the ABS unit fault codes? Not all readers can. When I had those lights it was shuttle valve switch failure on the ABS pump, but that does record a fault code in the ABS system. 2007 110 TDCi Station Wagon XS
It's worth noting that the original post is four years old, chaps. Darren
