![]() | Home > Maintenance & Modifications > Anyone fitted an sp 4x4 half bulkhead removal bar? |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
I fitted the Mudstuff one.
Easy enough to do - just awkward working on your news in a relatively cramped space. I used a combination of a reciprocating saw ( like wrestling with a wild woman) & a jigsaw. A compressed air rivet gun is extremely useful especially when working in the corners. Guy May your life be like toilet paper ; long & useful. |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Think mine was from Paddocks but with rounded "corners". Managed OK but you need to keep checking that the trim, which hides the cut edge, as you go along to get it right. Some good Hoe to vids on line also. Think there is a photo in my gallery. Jeff
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Thanks for the replies, I've found quite a bit of info on the rounded corner ones like you have fitted but nothing on the less common squared off one. There must be someone on here who has one.
Not sure what difference you think there is between a rounded one & a square one.
Fitting technique will be the same - remove metal & pop rivet in place. Measure twice before cutting once. Guy May your life be like toilet paper ; long & useful. |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777 ![]() ![]() |
I would imagine the radius cut outs are stronger.
