Home > Maintenance & Modifications > Anyone fitted an sp 4x4 half bulkhead removal bar?
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Thinking about reducing my bulkhead down a bit, not a full removal as my sub is mounted to the lower part and I find it useful when piling stuff in the back. I just need a touch more leg room so it feels a little less like I'm sitting on a toilet when driving.
I much prefer the look of the sp 4x4 one I found with the square corners rather than the big u shaped one. Has anyone on here fitted one or can recommend it?
Post #690019 1st Mar 2018 6:32pm
Chopperone
I fitted the Mudstuff one.
Easy enough to do - just awkward working on your news in a relatively cramped space.
I used a combination of a reciprocating saw ( like wrestling with a wild woman) & a jigsaw.
A compressed air rivet gun is extremely useful especially when working in the corners.
Guy May your life be like toilet paper ; long & useful.
Post #691635 7th Mar 2018 6:49am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Think mine was from Paddocks but with rounded "corners". Managed OK but you need to keep checking that the trim, which hides the cut edge, as you go along to get it right. Some good Hoe to vids on line also. Think there is a photo in my gallery. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #691663 7th Mar 2018 10:30am
LandymanStefan
Thanks for the replies, I've found quite a bit of info on the rounded corner ones like you have fitted but nothing on the less common squared off one. There must be someone on here who has one. Whistle
Post #691664 7th Mar 2018 10:35am
Chopperone
Not sure what difference you think there is between a rounded one & a square one.
Fitting technique will be the same - remove metal & pop rivet in place.
Measure twice before cutting once.
Post #691861 8th Mar 2018 6:50am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I would imagine the radius cut outs are stronger.
Post #692030 8th Mar 2018 7:57pm
