Home > Puma (Tdci) > Gearbox clatter!
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Gearbox clatter!
Hi all,
When in 2nd gear, low box, downhill with engine braking there is a very loud clattering coming from the transmission. Land Rover themselves say "it's normal" (no surprise there then). Has anyone else experienced the same noise? Could be other gears as well, I haven't tried them.
Thanks in advance.
Post #64351 19th Mar 2011 5:34pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
could be the cluch spring issue, havent had it myself so can't say but others will be along soon with there 2p's, the problem with low range and off road issues is its very hard to recreate for the dealer.
Post #64357 19th Mar 2011 7:17pm
spudfan
Ireland
Was this not mentioned sometime ago in relation to traction control? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #64364 19th Mar 2011 8:12pm
Bosun
I don't beleive they are related. Traction control chatter is a different noise, and a much higher frequency.
Post #64383 20th Mar 2011 8:54am
MK
in general gearbox clatter is caused by the input shaft axial play, which in turn is si suppressed by the inner central damper in the friction plate. The noise is common at very low speeds and shoudl go away at higher revs. Puma 110" SW
Post #64394 20th Mar 2011 11:15am
