![]() | Home > Puma (Tdci) > Gearbox clatter! |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
could be the cluch spring issue, havent had it myself so can't say but others will be along soon with there 2p's, the problem with low range and off road issues is its very hard to recreate for the dealer.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Was this not mentioned sometime ago in relation to traction control? 1982 88" 2.25 diesel
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
I don't beleive they are related. Traction control chatter is a different noise, and a much higher frequency.
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492 ![]() ![]() ![]() |
in general gearbox clatter is caused by the input shaft axial play, which in turn is si suppressed by the inner central damper in the friction plate. The noise is common at very low speeds and shoudl go away at higher revs. Puma 110" SW
